Hey Guys,
I have a whirlpool dishwasher with the problem of everyother button working. The first button from the left is the delay hours button. It doesn't work but the next one does, then next one is out and so forth.... Washer still works great but I sense a time when all the buttons will not work. It is a Quiet Wash Plus. Any ideas?
Thanks, Alex
Groups: APP Team
Hi.
Most likely it's the control panel, looks like it may be discontinued. Try to open the panel, remove the flex connector from the control board and clean the edge with isopropyl alcohol.
Good luck.
Post the results.
Simon.
