desde0
#1 Posted : Monday, October 29, 2012 11:55:20 AM(UTC)
desde0
Hi please i need the help pf someone technian here
i have an KUDS40FVSS4 Dishwasher but the overlay panel when you
press with your fingers does not star the unit.
first of all the the heavy duty light star blinking on /off but
when you press the button the started. then none of the cycles buttons
works or turn the light even the star/calcel button does not work
only works the light called 4-hour delay when you press it lights on but
itno matters for nothing because the star/cancel button does not work
please someone hell me!!!!
#2 Posted : Tuesday, October 30, 2012 11:26:29 AM(UTC)
Most likely the problem is a bad keypad which is a part of the control panel. The correction is to replace the control panel. If you need the correct part number, post the color of the control panel.
Here are the breakdown diagrams and Parts for Whirlpool KUDS40FVSS4 Dishwasher - AppliancePartsPros.com
