tjsteger
#1 Posted : Sunday, October 28, 2012 3:05:32 PM(UTC)
tjsteger
Hello,
I have what looks like a common problem. My ge spacemaker also turns the fan on when I open the door. I also have a problem with the turntable not working. Could you please let me know the part number for the door issue, and I will tackle the turntable later if I can. Other than that, micro works great. Hopefully I can repair door issue myself!
Thank You
Tim
Simon / APP Team
#2 Posted : Monday, October 29, 2012 10:05:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is a bad door sensing switch
Part number: WB24X829
located at the top of the door switch bracket.
Regarding the turn table you should check the coupling
Part number: WB06X10420
Here are the breakdown diagrams and Microwave parts for GE JVM1650WB008 - AppliancePartsPros.com
Post the results.
Simon.
