Dryer still runs but have no heat. Breakers are fine.
A model number may help others help you.
Also you cannot tell if the breakers are OK just by looking at them.
Try flipping the breakers off/on a couple times slowly, sometimes yiou can loose half the line without actually tripping a breaker.
If that does nothing then the next step is to check the voltage with a meter. |
THIS FORUM IS DEAD!!!!!!! |
