goodellf
#1 Posted : Sunday, October 28, 2012 9:43:19 AM(UTC)
goodellf
Refrigerator at about 32 degrees with setting of 1. Freezer at +5 degrees with setting of 2.
Fridge fan assenbly/diverter checks out OK. Freezer fan runs continuously. Compressor and fan run continuouly.
Have replaced the: Control panel, mother board and two thermesters in the fridge. Evaporator coils cleaned.
What is most likely cause of the fridge being to cold?
Simon / APP Team
#2 Posted : Monday, October 29, 2012 8:56:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is a broken door inside the air damper control
Part number: WR49X10091
Here are the breakdown diagrams and Fresh Food Section parts for GE PSW26MSRESS - AppliancePartsPros.com
You will need to replace the hole assembly.
Post the results.
Simon.
goodellf
#3 Posted : Monday, October 29, 2012 1:26:19 PM(UTC)
goodellf
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Simon: A repairman checked out the Air Damper Control and found it to be good. I called this component a "Fridge fan assembly/diverter."
Any other thoughts. Thanks, Frank
goodellf
#4 Posted : Monday, October 29, 2012 1:28:03 PM(UTC)
goodellf
:confused:
Simon / APP Team
#5 Posted : Monday, October 29, 2012 2:05:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Frank.
I suggest you to replace the part I listed above. Give it a day or two and if it's not going to work - return it back.
I'm suggesting that because with all the parts you had replaced there is nothing left but the damper control.
Post the results.
Simon.
