Orangevtx
#1 Posted : Saturday, October 27, 2012 4:01:33 PM(UTC)
Orangevtx
Hi. My dishwasher worked FINE a couple of days ago, but just tried to turn it on, and there are no light at all! I checked all buttons-no lights. I checked breakers- they were fine. I pushed the door in as hard as I could-no lights!
I checked manual- no help there either. :(
Please, please help me! I have an appraiser coming to the house in two days, and would really like to get this working again.
Thanks everyone!
Sincerely,
Patty
#2 Posted : Sunday, October 28, 2012 4:09:54 AM(UTC)
I think your model number is shown incorrectly.
KUDSO11LWHO should be kuds01ilwh0, following are for that unit.
I used small case letters so it is easier to see what the actual model number is.
Kitchenaid uses 1, i and l in their model number just to confuse things.
Parts for Whirlpool KUDS01ILWH0 Dishwasher - AppliancePartsPros.com
Lust because a breaker looks OK does not mean it is OK.
Try flipping it off/on slowly a couple times.
If that does nothing flip the breaker off and undo and check the wire nuts that connect the unit to the house wiring.
You did not say haw the unit was wire so I am guessing.
Sometimes they have a line cord attached and may even plu into a GFI which could be the problem.
The only way to be sure that the unit is getting power is to measure it with a meter.
Also on the wiring diagram you will see a thermal fuse. It is Item 6 in the Control Panel Parts section of the parts breakdowns.
This is a common problem.
Remove power to the unit and check this fuse. It should be 0 ohms.
If it is blown be sure to use the harness that comes with the new fuse.
File Attachment(s):
KUDS01il.pdf (1,110kb) downloaded 14 time(s).
Orangevtx
#3 Posted : Sunday, October 28, 2012 6:29:24 AM(UTC)
Orangevtx
Thanks so much for your quick reply! I am going to try the breaker first. That is...if I can find which one. Grrr
Orangevtx
#4 Posted : Friday, November 2, 2012 2:24:17 PM(UTC)
Orangevtx
Thanks so much! I was afraid to test the fuse, and got a repairman over, and YES it WAs the fuse! Thanks for all your help! He relaced the fuseable link, and the new wiring too.The parts were only about $26.00, but in total, with labour, it came to about $150.00! I wish I had the nerve to do it myself. He didn't even shut any power off! lol
You guys are awesome!
patty (Dryer Repair)
by gograndma1 5/19/2010 3:59:37 AM(UTC)
Patty61 (Oven Repair (including Ranges and Cooktops))
by patty61 11/20/2008 12:25:00 PM(UTC)
Patty M (Washer Repair)
by pmustard 12/22/2007 3:44:02 AM(UTC)
