flyin34
#1 Posted : Thursday, October 25, 2012 11:36:52 AM(UTC)
flyin34
Gene, last month after checking all diagnostics on my ice maker, it started working again....then I removed the ice bin to use ice in an ice chest and didn't install the ice bin proerly and it sat like this overnight. Im guessing it was blocking the optics since it was not placed back correctly. Noticing it the next day I made sure the ice bin was seated down all the way and ice maker hasn't made ice since....
So, I have run all the diagnostics again. Water valve shows to be ok. Optics light blinks twice, but stays red when lever on left is pushed. Harvest cycle will initiate but I can't get water to dispense during harvest cycle. Test point N and L shows no voltage, but still can run harvest cycle by jumping T and H. Jumped L and V but no water.
So, it seems everything is working ok except will not dispense water during cycle. Line is clear and valve dispenses water through freezer line when I switch leads but not during harvest cycle...
What next??? Thanks
