Mmiket72
#1 Posted : Monday, October 22, 2012 10:29:48 AM(UTC)
Mmiket72
The front right burner only burns on high when turned on. I replaced the infinity switch and it operated correctly once. After being turned off and back on it would only burn on high no matter where the switch is set. Thought it might be the burner so replaced the burner dual element(74011986). It still only burns on high at all switch settings. Wondered if the burner thermo controls were bad and it burned the switch out before the new burner was installed?
Help?
MT
rickgburton
#2 Posted : Tuesday, October 23, 2012 4:42:04 PM(UTC)
rickgburton
Groups: Expert
The switch #74010824 needs to be replaced again.
