Our Bosch dishwaher has a loud grinding noise when it is running that it did not used to have. It continues to run on the wash cycle until you turn it off. It does not switch to the rinse/dry cycle.:confused:
The correct model number is SHU4302UC/U06. I made in error in typing it.
Thanks!
Try looking for a bad solder joint on the control board inside the door. It means dismantling the door. This is a very common problem with these machines.
