oceanhill
#1 Posted : Saturday, October 20, 2012 8:03:21 AM(UTC)
oceanhill
The compactor can function when the starter knob is turned on once and when it is complete door can not open completely, then turn one more time, i can open the door. What's the problem?:(
cozumel2
#2 Posted : Monday, October 22, 2012 2:16:58 PM(UTC)
cozumel2
The ram is not retracting completely. Remove the top and look for a limit switch that closes and turns off the motor. (There may be 2) They are usually mounted on 2 very small diameter machine screws. Likely it is out of place or the activator arm is bent. Loosen the screws and adjust the switch so the ram has to travel up a bit further. Can also bend the activator arm a bit to accomplish the same thing. UNPLUG THE UNIT WHEN MAKING ANY ADJUSTMENTS
Kitchen Aid Trash Compactor stopped- KTTS505ESS (Trash Compactor Repair)
by etiger 9/15/2020 10:13:18 AM(UTC)
How to remove JennAir trash compactor? (Trash Compactor Repair)
by snerdlybosco 12/10/2019 2:43:45 PM(UTC)
Trash compactor wont work right (Trash Compactor Repair)
by Lynnylove01 3/13/2019 7:45:54 AM(UTC)
ge Trash compactor pedal broken can't open (Trash Compactor Repair)
by tahoemark 7/25/2017 10:13:08 AM(UTC)
Trash compactor won't turn off (Trash Compactor Repair)
by fgg 8/23/2014 5:14:29 PM(UTC)
Trash compactor gears (Trash Compactor Repair)
by jfkeats 3/27/2014 1:59:16 PM(UTC)
Kenmore Trash Compactor (Trash Compactor Repair)
by verna2198 2/10/2014 4:47:46 AM(UTC)
trash compactor (Trash Compactor Repair)
by ld.rob@@yahoo.com 1/2/2014 9:51:28 AM(UTC)
broan trash compactor (Trash Compactor Repair)
by SPELLINGRA 6/17/2013 1:00:48 PM(UTC)
Trash Compactor Solid Pack does not function (Trash Compactor Repair)
by frd1952 4/3/2013 12:19:53 PM(UTC)
Whirlpool trash compactor limit switch keeps failing (Garbage Disposer Repair)
by bhorenkamp 1/10/2013 12:18:53 PM(UTC)
trash compactor motor stops (Trash Compactor Repair)
by oldschool51 1/2/2013 11:08:03 AM(UTC)
jenn-air trash compactor broken gear? (Trash Compactor Repair)
by mljdd 4/19/2012 11:02:49 AM(UTC)
GE Trash Compactor won't stay on (Trash Compactor Repair)
by ddecker 12/9/2011 9:34:07 AM(UTC)
GE trash compactor ram doesnt return to top (Trash Compactor Repair)
by jlarkins 8/1/2011 9:04:29 AM(UTC)
