RDSandy
#1 Posted : Monday, January 28, 2008 10:09:19 AM(UTC)
RDSandy
Roper top load washer will not agitate or spin. It fills and drains but when it hits the agitate cycle it makes a humming noise but no movement. Can not move it by hand.
#2 Posted : Monday, January 28, 2008 3:32:14 PM(UTC)
Most likely the problem caused by the worn out motor drive coupling.
In order to provide the most accurate advise I need the complete model number of the washer.
