My bake element blew a hole in it. I replaced the bake element and now the oven won't heat up. I have been hearing that it is the clock. My concern is that the clock seems to work. I can set the oven tempertature either on bake or broil but nothing happens. The clock waits for the temperature but no heat comes from either the broil element or bake element. What is most likely the problem. Could it be the temperature sensor? or wires behind the bake element? thanks :( :confused:
Groups: APP Team
Hi. Make sure that you have the 240VAC to the oven. If you do - check the voltage across the element (240VAC), check the wires to the relay board. Check the hi-limit thermostat (to access it remove the main top or rear panel). You should read continuity across it's terminals Part number: 74009837
