This Fridge has worked flawlessly since new untill it was unplugged for cleaning. Now it doesn't cool like it should and the strip between the doors is too hot to touch. I've read where I should check the condenser fan. I'll try that tomorrow. Any other ideas? Thanks, Al
I am assuming you were cleaning the condenser coils under the unit.
The symptom is indicative of poor cooling of the condenser coils so the fan, dirty condenser coils, plugged rear vents or vents in the kick plate are the usual culprits. |
THIS FORUM IS DEAD!!!!!!! |
Actually it was unplugged for the inside to be cleaned. I'll look at the fan and coils as soon as get a chance. I'll be needing this thing to work before the end of this month when I move into the house where it's at. It's such a nice well made /designed unit. I'd really like to get it working. Thanks for the reply....Al
