olsonae
#1 Posted : Wednesday, October 10, 2012 11:10:01 AM(UTC)
olsonae
Hello All from a new member. I would appreciate your thoughts on a wall oven where the center broil element won't heat. It won't heat in center only mode, or full broil. Could it be the element? The connector? The electronics? The only troubleshooting I could think of was to turn the breaker on and off, in case the electronics got confused, but no luck. Thanks for your advice!
#2 Posted : Thursday, October 11, 2012 1:44:50 AM(UTC)
Parts for Whirlpool KEBS107SBL00 Wall Oven - AppliancePartsPros.com
See the attachment for the tech sheet
It could be ant of the causes you mention.
I would start by unplugging the unit and removing the element and then check it with a meter. should be around 30 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
KEBS107.pdf (464kb) downloaded 1 time(s).
olsonae
#3 Posted : Thursday, October 11, 2012 12:45:23 PM(UTC)
olsonae
Thank you very much! I will follow your advice and see what turns up.
olsonae
#4 Posted : Sunday, October 14, 2012 7:19:48 AM(UTC)
olsonae
Originally Posted by: denman Go to Quoted Post
Hello Denman,
Thank you for your help. Looks like most of the posts on this forum are professionals talking to professionals or experienced DIYers. This was my first attempt at a major appliance repair, but I am not averse to trying basic repair routines, so I appreciate your time to help a rookie.
The good element has a steady 37.6ish ohms; while the non performing element started around 12 and kept rising slowly, so a new element looks in order before I call Sears. Also, near one part of the element is a small spray of carbon (~ 2 in x 2 in) on the element bracket. Is this the point of failure?
Thanks again!
#5 Posted : Sunday, October 14, 2012 1:35:02 PM(UTC)
[COLOR="Blue"]Also, near one part of the element is a small spray of carbon (~ 2 in x 2 in) on the element bracket. Is this the point of failure?[/COLOR]
Yes that is what it sounds like.
