I replaced my control board and powered up the machine and it automatically started it's diagnostic test (I guess that's normal). It ended up (at least I think it ended) at "H" in the timer window. So what does code of H mean? Was the test still running or was that an error code?
I had to replace the control board because the old one had a really, really bad short/melt spot around the relay area (no resoldering this one) there was black (fire/smoke) damage on the board and the plastic casing. I suppose some water may have gotten in there somehow. Anyway, it's replaced, just need to know what H means.
Thanks.
What is the part number of the new control board?
676961 I got it from bosch and it looked exactly identical.
Try to unplug the dishwasher for a few minutes and plug it back.
