Error F-21 says washer can't drain. The washer will not start a cycle or pump existing water out.
How do I get the lower panel off the front to allow me to check the drain hose and other connections?
I also have a front seal that is torn at the bottom of the door. Is it possible to rotate the seal 180 Degrees to put the seal at the top?
The only problem with the seal is that it leaks sometimes.
Thank you!
