siramack
#1 Posted : Sunday, October 7, 2012 7:28:20 AM(UTC)
siramack
The washer won't spin in the spin cycle after fixing a leak with tub seal and bearing kit-triplelip seal and bearing hub kit #21002237 everything else works fine
sidfink43
#2 Posted : Tuesday, October 9, 2012 4:28:29 PM(UTC)
sidfink43
Operate it with the front cover off to see if the motor is turning or if the transmission is not turning.
Washer won't spin in spin cycle (Washer Repair)
by LA Stump 4/14/2010 7:13:48 AM(UTC)
washer won't spin in spin cycle (Washer Repair)
by carlous 3/6/2009 6:47:04 AM(UTC)
