oceanhill
#1 Posted : Saturday, October 6, 2012 4:18:34 PM(UTC)
oceanhill
October 6, 2012
It looks like the starter switch inside cannot be firmly attached with theoutside control knob securely.
Starter Switch Loose
The starter switch seems to be loose behind the control panel.
Should not the starter switch be secured to firmly catch the controlknob when installed?
When I turn control knob to start, the control knob does not catch thestarter switch inside but the compacting machine starts and makes loud noise.The compacting seems to work a little. When I turn the control knob to stopseveral times, the compacting stops.
However, I can only open the compactor about 10% and the rest is stuck.
Then by wiggling the control knob (start & stop few times) I was able toopen the compactor.
How do I repair this?
Thanks.
Model # KUCC151B
Trash compactor wont work right (Trash Compactor Repair)
by Lynnylove01 3/13/2019 7:45:54 AM(UTC)
ge Trash compactor pedal broken can't open (Trash Compactor Repair)
by tahoemark 7/25/2017 10:13:08 AM(UTC)
Trash compactor won't turn off (Trash Compactor Repair)
by fgg 8/23/2014 5:14:29 PM(UTC)
Trash compactor gears (Trash Compactor Repair)
by jfkeats 3/27/2014 1:59:16 PM(UTC)
Kenmore Trash Compactor (Trash Compactor Repair)
by verna2198 2/10/2014 4:47:46 AM(UTC)
trash compactor (Trash Compactor Repair)
by ld.rob@@yahoo.com 1/2/2014 9:51:28 AM(UTC)
broan trash compactor (Trash Compactor Repair)
by SPELLINGRA 6/17/2013 1:00:48 PM(UTC)
Trash Compactor Solid Pack does not function (Trash Compactor Repair)
by frd1952 4/3/2013 12:19:53 PM(UTC)
Whirlpool trash compactor limit switch keeps failing (Garbage Disposer Repair)
by bhorenkamp 1/10/2013 12:18:53 PM(UTC)
trash compactor motor stops (Trash Compactor Repair)
by oldschool51 1/2/2013 11:08:03 AM(UTC)
by oceanhill 10/20/2012 8:03:21 AM(UTC)
jenn-air trash compactor broken gear? (Trash Compactor Repair)
by mljdd 4/19/2012 11:02:49 AM(UTC)
GE Trash Compactor won't stay on (Trash Compactor Repair)
by ddecker 12/9/2011 9:34:07 AM(UTC)
GE trash compactor ram doesnt return to top (Trash Compactor Repair)
by jlarkins 8/1/2011 9:04:29 AM(UTC)
Trash compactor will not come up (Refrigerator & Freezer Repair)
by amalifeline 6/26/2011 4:02:55 PM(UTC)
