carlsic
#1 Posted : Wednesday, October 3, 2012 6:19:15 PM(UTC)
carlsic
I am familiar with thr repair of an older fridge with the defrost timer, heater and thermostat, but cant find any of that on the parts diagram. Fridge is 65 F freezer is 0 F. inside edge of left door (bottom freezer model) is quite warm. Fan is blowing in fridge, light frost in freezer. is there any way to manually start the defrost cycle and go from there?
#2 Posted : Thursday, October 4, 2012 1:39:41 AM(UTC)
Replacement parts for Whirlpool GX5SHTXVB00 REFRIGERATOR | AppliancePartsPros.com
It has a number of diagnostics you can run.
Is the compressor running ll the time? This would be a symptom of a defrost problem.
If it is cycling normally then it is probably a problem with the damper (Item 15 in Section 6) of the parts. It controls the amount of cold air entering the fresh food section. Could be a problem with it, or the control electronics or the fresh food thermistor.
carlsic
#3 Posted : Thursday, October 4, 2012 2:13:16 AM(UTC)
carlsic
The compressor is running all the time.
I don't see an attachment, just a link to the parts list.
I also unplugged it for about a half hour trying to reset it. still acts the same, but the left door is no longer warm on the inner edge.
thx.
#4 Posted : Thursday, October 4, 2012 5:53:57 AM(UTC)
Here is a second attempt at attaching the tech sheet
File Attachment(s):
GX5SH.pdf (426kb) downloaded 18 time(s).
You cannot view/download attachments. Try to login or register.
carlsic
#5 Posted : Tuesday, October 9, 2012 6:00:30 PM(UTC)
carlsic
Thanks for the tech sheet. My wife cleaned the fridge before I had a chance to try it and i am guessing thawed out the damper. It has been working fine for 4 days.
