AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Quiet Partner II - Light flashes, can't get it to reset
No replies the first time (9/20) ... Thought I'd try again ...
I've searched several threads, but I can't seem to find one that matches the problem that I'm having. On my unit, the light above 'Hi-Temp Wash' is the one that is flashing. I have read some of the other threads, and I've tried the 'Heated-Dry, Normal, Heated-Dry, Normal, Cancel' sequence that I've seen some people try, but that hasn't seemed to do anything.
Sometimes, the light seems to flash in a 'code' manner, then it just switches to a constant flashing. I've tried turning the dishwasher off at the light switch, and I've also tried flipping off the breaker.
It was working fine this past weekend ... Now it just doesn't want to cooperate.
Any suggestions?
Thank you, so much, for any help that you can provide!!
Okay ... I posted Twice on here, and did not get any sort of reply ...
I guess I'll go back to ************************.com ... I can at least get some sort of acknowledgement from them.
Thanks for nothing!
Dishwasher Repair
