This machine is in a hotel. It is a coin operated model. When I open the access panel with my key, I can turn the timer to start the machine and then it runs through all it's cycles fine. But when it shuts off, the timer actuater is pointing down so that a paying customer will not be able to use it. What can I do? It seems as though the timer has "jumped time" somehow. I appreciate any help given.
Sorry no one has posted back to you yet but I have not worked on coin operated machines and it may be that none of us who respond regularly on this Forum do also. This site does have a parts breakdown for that machine if you need to research part replacements.
If you do not get a response I think you will have to try elsewhere.
Good luck, wish I could have been of more help.
