309brasstown
#1 Posted : Tuesday, October 2, 2012 4:36:53 PM(UTC)
309brasstown
My old oven stopped working the light will not even come on when I turn it on the top or bottom elements will not turn on?
309brasstown
#2 Posted : Tuesday, October 2, 2012 4:41:33 PM(UTC)
309brasstown
I have no idea what that means I'm a woman with a broken stove can you explain.
#3 Posted : Wednesday, October 3, 2012 12:41:45 AM(UTC)
A model number may help others help you.
Model Number Locator
Since the elements and the light all went out at the same time it sounds like a power problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
