The front right burner can heat from 6"-9"...the smaller burner stays on even when the knob is in the off position. Tried resetting by shutting off breaker. Checked the wires connected to the computer panel ... stayed on. :eek: Disconnected wires to heating element under the glass top so we can use the stove. What part do we need? Is it a switch? :confused:
THIS FORUM IS DEAD!!!!!!! |
