AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Direct Drive Washer Agitator Only Turns Clockwise
Groups: APP Team
Hi. Based on the info you provided the problem is a transmission Part number: 3360629
Thank you. Simon.
Originally Posted by: Simon / APP Team Hi. Based on the info you provided the problem is a transmission Part number: 3360629
Thank you. Simon. Simon, I want to repair the existing transmission. It does come apart and the gears inside with the probable exception of the agitator gear, which apparently deforms according to the thread I referenced, are sound. I have looked at cleaned them before reassembling the transmission after replacing the input shaft seal and refilling with gear oil. Thank you. I hope that other commenters have source of new or used parts. Roger
Washer Repair
