pigottman
#1 Posted : Thursday, September 27, 2012 6:07:38 AM(UTC)
pigottman
Water will not shut off completely to my washer. It continued to slowly fill with water during all parts of cycle and when the washer is on off setting. The only way I could stop the water from entering washer was to shut it off at the water inlet from the house. Help!
Simon / APP Team
#2 Posted : Thursday, September 27, 2012 8:13:33 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is a bypassing water inlet valve which you need to replace Part number: 134890600
Here are the breakdown diagrams and Replacement parts for Frigidaire GLET1031FS4 LAUNDRY CENTER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
pigottman
#3 Posted : Friday, September 28, 2012 3:43:33 AM(UTC)
pigottman
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Thanks, Simon! What is the best way to access this part? It appears that I need to remove the dryer to be able to remove the panels on the washer which is proving to be quite pesky!
Simon / APP Team
#4 Posted : Friday, September 28, 2012 9:13:35 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull the unit off the wall.Disconnect the power,turn the water off, remove the hoses.
Remove 2 screws at the bottom of the front panel, one on each side, and pull it down.
Disconnect the wires from the lid lock and remove 2 screws one on each front corner.
Lift and pull out the top.
Take one screw holding the valve out from the back.
Good luck.
Simon.
pigottman
#5 Posted : Wednesday, October 3, 2012 8:51:28 AM(UTC)
pigottman
Hi.
Good luck.
Simon.
So, I've gotten to the part and exchanged it, but I am not sure that I plugged the red and white plugs into the new part correctly. (The washer seems to be working so far, but I want to make sure) I have the white plug at the top and the red plug at the bottom, but I'm not sure that I didn't flip the plugs top to bottom which would reverse the wires. I believe the white plug has one yellow and one blue wire and would like to be sure that I have them in the correct order top to bottom. I have the red plug with the red/black wires at the bottom of this plug. Does this matter? The washer is working and seems to be filling correctly.
Thanks,
Keegan
Simon / APP Team
#6 Posted : Wednesday, October 3, 2012 9:48:30 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the plugs are installed incorrectly the hot and cold water will be switched around. Select cold water only wash and check.
Simon.
pigottman
#7 Posted : Wednesday, October 3, 2012 9:55:50 AM(UTC)
pigottman
Hi.
Simon.
Thanks so much, you've been super helful! The part arrived quickly and was fairly easy to replace thanks to your help. We have a well an have always had a problem with sediment clogging the filter on this part. Several months ago, we took the filter out of the water inlet valve because it is so difficult to clean. I'm sure that is what caused the filling problem, so we have put a filter into the hose at the wall which is a bit easier to clean. Thanks again!
Keegan
Simon / APP Team
#8 Posted : Wednesday, October 3, 2012 10:16:24 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
