My Jenn-air oven shuts off after only a few seconds. It seems to works better when it's warm. If you can get it to start heating it will work normal. This has Been going on for about a year off and on. It would normaly start working after a few try's but this time it will not.
Well after jiggling all all of the wires I managed to get the broiler to turn on. After it gets hot the oven will work like it should. That will let me finish my dinner that I started preparing hours ago but this problem has to be fixed
Groups: APP Team
Hi.
What is not working - bake,broil or both?
Would you please be a bit more specific on what did you do to make it work.
Thank you.
Simon.
Neither one would work. after I just wiggled all the connections the boiler finally work. After the oven got warm the bake would work
Groups: APP Team
Can you please be more specific on what connections exactly you wiggled?
Simon.
Every wire and connector behind the front panel
Groups: APP Team
Hi. Based on the information your provided it's a power relay board Part number: Y04100260
There is still a chance that it's the clock control Part number: Y04100263
The wire harness is not available anymore. You can return unused parts even if you installed them. Thank you. Post the results. Simon.
