Washer stopped in rinse/drain cycle...and the door was locked...Door would not open. Pulled off front cover and manualy released door. Found yellow and red wire going to thermistor broken off. Repaiured wiring but still not powering up properly. Comes on now and then and when I try to start a new wash cycle, as soon as the door lock initiates, the power goes out on display again...any ideas???
Originally Posted by: DJBNF  Washer stopped in rinse/drain cycle...and the door was locked...Door would not open. Pulled off front cover and manualy released door. Found yellow and red wire going to thermistor broken off. Repaiured wiring but still not powering up properly. Comes on now and then and when I try to start a new wash cycle, as soon as the door lock initiates, the power goes out on display again...any ideas??? any ideas...anybody???
