DrewDickerson
#1 Posted : Tuesday, September 22, 2009 1:53:04 PM(UTC)
DrewDickerson
The oven thermo on our stove is broken and I purchased a new part here. The problem is I am not sure how to get to the thermostat to replace it. How do you lift the stove top on this model? It seems that the surface burners are attached to the top and I am not sure how to take them apart. Any help would be appreciated.
#2 Posted : Wednesday, September 23, 2009 5:12:06 PM(UTC)
If you lift the burners up then you'll see two screws under each burner which have to be unscrewed. Lift up the top panel and release the front support. Release the panel rear hinges and put it aside.
Remove all knobs. Remove all screws holding the manifold panel and put it aside.
Unscrew all screws holding the burner box and put it aside as well.
Here are the breakdown diagrams and Replacement parts for GE JGBS23BEA5WH | AppliancePartsPros.com
johnfixesstuff
#3 Posted : Wednesday, April 30, 2014 7:58:18 PM(UTC)
johnfixesstuff
I replaced the oven thermostat for my GE XL44 and wrote up all the steps on my blog with lots of pictures: John Fixes Stuff: GE XL44 Oven Will Not Turn Off-How To Replace Oven Thermostat Assembly
