gums
#1 Posted : 16 years ago
gums
There is no heat during the drying cycle. The element "looks" OK.
Are there thermostats or something else to look at as a culprit before I invest in a new heating element? If so what may they be and where would I locate them in the dishwasher?
I am an amateur repair guy. Would I be better off calling Maytag?
#2 Posted : 16 years ago
Replacement parts for DW860 models | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16007822.pdf
Just because it looks OK does not mean that it is OK. Best to check it with a meter.
See Page 3-16 in the manual
Cannot say, depends on whether you have the time to repair/check it.
gums
#3 Posted : 16 years ago
gums
I'll give it a go. Time is my best commodity.
Maytag jetclean dishwasher does not dry dishes? (Dishwasher Repair)
by SNAFUHL 15 years ago
Dishwasher does not dry dishes (Dishwasher Repair)
by mbreuhaus 15 years ago
dishwasher does not dry dishes (Dishwasher Repair)
by yensmavahoj 17 years ago
