Icemaker not making ice. The LED light on the side of the on off switch is not lit. Does this indicate a problem somewhere other than the icemaker. Where should I start troubleshooting. The ice dispenser and water dispenser work. Thanks
Checked voltage, only have 35 volts at controller and 105 volts at the plug in. Any ideas? Thanks
