Well the dishwasher won't power on again. About 2 weeks ago the thermal fuse blew, I replaced it ($35) and guess what? It blew again :(
Is there anything I can do or should I just scrap this P.O.S. and get a new one?
Thank you,
Matt
I searched around and found that if you didn't replace the wires with the new wires that came with the thermal fuse that could be the problem - well I didn't replace them. I didn't see why I would bother but now I guess it makes sense if it's going to cause resistance. I will get another fuse tomorrow. Should I check anything else?
Thanks,
Matt
