my washr wont fill with water spin cycle works fine.
I did some trouble shooting it spins fine but wont fill with water at all. Checked water lines and such. I put a volt meter on water fill valve coils and getting 120 volts at all times on both coils. I did a resistance check and am getting 670 ohms on both coils. Not sure which part to order any help is appreciated this whirlpool is only two years old.
