GlenLForde
#1 Posted : Thursday, September 6, 2012 5:11:26 PM(UTC)
GlenLForde
My front left burner isn't getting hot, how do i test to find out which part I need between the (Infinite Switch) or (Radiant Surface Element)
#2 Posted : Friday, September 7, 2012 3:53:23 AM(UTC)
Replacement parts for Maytag MER5751BAW RANGE- S/C F/S ELE | AppliancePartsPros.com
Looks like it is the 6 inch burner. It is item 16 in section 2. Click on it's picture for more info and a Q&A section.
I would check it first.
It should be approximately 50 ohms.
If OK then it is probably a bad infinite control.
Also be sure to check the wires going to it as one of them may have burned out.
