Our washing machine had water come out from underneath of it & go all over the floor & there are grease spots underneath the washer, also. Can you please tell me what the problem might be & what parts I might need to fix it?:confused:
Normally on these machines when there is water it is because the tube going from the tub to the water level switch is blocked.
The bigger problem is the grease, which may mean the transmission seal has failed and that means replacing the transmission, or if it is not damaged replacing the gasket and transmission oil.
