Would like to know if a new control panel is needed because the panel lights up and works, but the start button is the only one that will not allow to be pushed. If you wait too long it shuts down.
Most likely the problem is a bad keypad but there is a small chance for the control board to be bad as well. I would replace the keypad first. - The keypad Part number: 154369701
