gandswalton
#1 Posted : Sunday, September 2, 2012 1:34:35 PM(UTC)
gandswalton
So, I defrosted the fridge because I figured the air flow wasn't flowing well. The temp in the fridge got up to 70 degrees F! Yet the freezer temp remained just around freezing.
I took everything out of the unit and manually defrosted the coils in the back. This happened about a month or two ago. Then the temp came back down to normal. Now, I've checked the fan, the air flow and everything else. The temp in the fridge seems to only make it to about 42F. Yet the freezer is still right on the money.
How do I check to make sure that the air flow at the bottom of the fridge isn't blocked? Any other suggestions?
gandswalton
#2 Posted : Sunday, September 2, 2012 5:52:35 PM(UTC)
gandswalton
Ok, so I checked the temp in the freezer and it was 20F. I guess this is supposed to be -5F (ish). Correct? Would it then be a compressor issue?
