dbc
#1 Posted : Sunday, January 27, 2008 4:45:06 AM(UTC)
dbc
Whirlpool Washer- direct drive (5 to 10 years in age). Everything seem to work properly except spin cycle. Once the spin cycle gets to top speed, the tub starts to jump around out of control. Could bad bearings in the tub support cause this?
If the bearing are the problem, I see that a repair kit is available. How hard is it ti replace bearings? Do you have to press them into place? Does the tub support have the bearing included? Would it make moe sense to by the tub support if braeing included?
