mistymountainhop
#1 Posted : Tuesday, August 28, 2012 3:15:34 PM(UTC)
mistymountainhop
The oven door wont close, needs a part to replace but not sure which part fits this model. I have seen lots of similar issues but none that match my model. Please advise
#2 Posted : Wednesday, August 29, 2012 3:04:00 PM(UTC)
The model number you posted dose not come up. Verify and repost it please.
mistymountainhop
#3 Posted : Saturday, September 8, 2012 11:20:31 AM(UTC)
mistymountainhop
Sorry, I guess the model # is rbs305pd. it is a drop down door. It just doesnt close enough to be able to heat up. if I push it in about an inch and hold it, the oven begins heating. Assume it is either the hinges or spring or both? Thank you for replying...
#4 Posted : Monday, September 10, 2012 4:57:01 PM(UTC)
Possible that the problem is a bad door hinge. You have to replace both of them even if only one is bad. Left and right side hinges are identical.
- The door hinge Part number: 4455525
New hinges but oven door wont close (Oven Repair (including Ranges and Cooktops))
by SeayHome24 7/4/2013 6:28:04 AM(UTC)
Dacor oven door wont close. (Oven Repair (including Ranges and Cooktops))
by rp716 11/17/2010 5:40:18 AM(UTC)
oven door wont close all the way (Oven Repair (including Ranges and Cooktops))
by jbethfoust 1/26/2009 8:02:05 AM(UTC)
