I recently installed part #AP3775506 which is the electronic control board for a Kenmore Dishwasher. Priod to installation the dishwasher ran perfectly except that the regular cycle would not shut off after the dishes were washed & dryed. After installing the new control board, I had my wife run a load of dishes through the regualr cycle and everything worked ok and the cycle shut off but no time ever appeared on the machine. After the cycle was completed there was/is a little green light that keeps blinking on and off indicating that the load is "clean". There is nothing that I can push to get the light to go off. Opening & closing the door doesn't help either. Now nothing works at all. Is the control board deffective, did I do something wrong (Seemed like an elementary installation) or do I have something else that is causing my problem.
Hi again. My Dishwasher is model 665.1593200. I have seen places on line that tell me to reset by pushing a combination of buttons. One of those buttons is always "heated dry" but my machine doesn't have that button.
