My Quiet Partner III just doesn't want to start. If I hit the "DELAY" button it will only show a 4H and will no longer scroll through the different times. I can change the type of wash cycle, but I can't change it from "HEATED DRY" to another type of wash style. The only button that seems to work correctly is the "CANCEL/DRAIN" button. It did work again last night after it did this once, but we can't get it to work again. It does not have any blinking lights, and the "NORMAL" "HEATED DRY" "NORMAL" "HEATED DRY" sequence did nothing either. I am an automotive Master Tech, I think I can figure it out if I can get some diagnostic help.
