Millersix
#1 Posted : Sunday, August 26, 2012 9:32:09 AM(UTC)
Millersix
Hello,
I've been reading the posts here and have found several trouble shooting tips. My oven and broiler will not light. I hear clicking and gas flow but no ignition then it cycles off for a time then retries. Although it sounds like I have flow I checked the gas valve resistance and I come out with about 220 ohms to common on both terminals. Since the broiler igniter is easier to see we started the broiler and did not see any spark. Since I believe there is gas present I decided to try a manual start with a flame as we did in the old days. I turned on the broiler and held the flame to the burner and it fired up and continued to heat up. I suspect a possible faulty spark module but am leery to spend the $225.00 if I'm not correct. A new stove is 500.
Any thoughts or extra diagnostic steps would be appreciated.
Simon / APP Team
#2 Posted : Monday, August 27, 2012 10:26:05 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the spark module Part number: W10331686
Here are the breakdown diagrams and Replacement parts for Whirlpool SF368LEPQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER | AppliancePartsPros.com
You can return the parts if you get it from APP even if they been installed.
Read the attached document.
Simon.
File Attachment(s):
Theory of Direct Spark Ignition.pdf (95kb) downloaded 1 time(s).
Frigidaire FGF366BCB Oven and Broiler won't light (Oven Repair (including Ranges and Cooktops))
by macche 8/22/2019 4:28:11 AM(UTC)
KitchenAid Oven and Broiler won't light (Oven Repair (including Ranges and Cooktops))
by krw2dbw 6/21/2012 12:38:11 PM(UTC)
Caloric oven and broiler won't light (Oven Repair (including Ranges and Cooktops))
by calorwht 2/14/2011 10:14:49 AM(UTC)
GE XL44 oven and broiler won't light (Oven Repair (including Ranges and Cooktops))
by jonsmilburn 7/13/2010 7:13:46 AM(UTC)
by Tugboattugger 9/22/2009 4:28:52 PM(UTC)
GE Oven and broiler won't light (Oven Repair (including Ranges and Cooktops))
by brokenoven 12/6/2007 4:45:19 PM(UTC)
