jmarques6
#1 Posted : 13 years ago
jmarques6
drain line connects to one inch drain post under ice bin. Connected to post is drain tube by clamp. Moved ice maker and it puled on post. Water now leakes from around outer edge of drain. How do I access drain post to repain
jmarques6
#2 Posted : 13 years ago
jmarques6
drain line attaches to drain plug at rear of ice bin. In moving ice maker it must have broke or dislodged drain plug. Drain line is attached to plug with clamp. Water now leakes from around drain line . How do I repair or replace plug
