jdh56
#1 Posted : Saturday, August 25, 2012 4:43:37 AM(UTC)
jdh56
My oven used to read 100degrees when you turned it on and would stay there until the temp got above 100. Now.....it reads 220 when I turn it on and although it heats up it seems to read way higher temp than the actual temp.
jdh56
#2 Posted : Monday, August 27, 2012 6:03:51 AM(UTC)
jdh56
Thanks for the answer. I'm not sure this is the issue for a couple reasons:
1. The sensor worked perfectly one day and then 150 degrees off the next time I tried the oven.
2. I got the proper resistance readings here and tested it and it reads 1100 ohms at room temp as it should.
