My ice maker is not filling with water. Supply tube is clear not frozen. I have current at the wire to the water valve when it cycles. When I check continuity on the solenoids, I get 190 ohms on the inlet and after filter 35w solenoids. Is this the correct resistance or are my solenoids bad? I notice on the 20w solenoids that go to the door water I get 300ohms. Here is my valve assembly if you need a visual.  [URL="http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=2071734&image=1"][/URL]
Quote:...I have current at the wire to the water valve when it cycles... How did you find it? What about voltage? Gene.
