adrianbolso77
#1 Posted : Saturday, January 26, 2008 1:13:04 PM(UTC)
adrianbolso77
The dryer won't start. I have checked the power supply, and I am getting power.
I also cheked the start switch for continiuty and it is ok.
Waht else should I checked?
abbie
#2 Posted : Saturday, January 26, 2008 6:02:31 PM(UTC)
abbie
If you have a meter and you checked the power and was getting 240 volts,i would then check the door switch for continuity.
adrianbolso77
#3 Posted : Sunday, January 27, 2008 4:28:45 AM(UTC)
adrianbolso77
Thanks but, I checked the door swicth and it has continuity.
What else should I checked?
a1lady
#4 Posted : Tuesday, January 29, 2008 7:06:04 AM(UTC)
a1lady
i have a whirlpool dryer with the same problem my dryer door switch has a brown and blue wire on the left side and a white on the right i checked the blue to white and get a connection but when i check brown to white nothing ? is switch bad?
adrianbolso77
#5 Posted : Tuesday, January 29, 2008 5:25:10 PM(UTC)
adrianbolso77
if you make the switch you should have continiuty, if you do your switch is ok.
