Hello,
I have the Kitchaid side-by-side refrigerator (model # ksra25fkss00) and the icemaker is no longer working. I had an issue 1.5 years ago because the lining of the icetrays had disintegrated and the ice was not coming out of the trays. I ordered part number 1129316 from appliancepartspros.com. That fixed the problem. Now, it is not working again. For a few days, the icemaker would not stop making ice. It kept overflowing. Then it just quit working. I took the unit out and removed the ice from the trays by letting it melt. I then put the icemaker backinto the freezer. Water filled the trays, but it will not eject. What could be the problem...
Thanks.:(
