replaced the ignitor in the ove and it still wont light, wondering what the problem could be.
Groups: APP Team
Hi. First of all check if there is 120VAc to the unit. Assuming it is check the oven thermostat. Using the multimeter check the continuity at the contacts with the thermostat ON.(unplug the oven). No continuity - replace the thermostat Part number: 316032411
To make sure you may install a temporary jumper wire on the thermostat contacts. The next thing to check is the safety gas valve. Same test for continuity. If it's open - replace it. The safety gas valve Part number: 3203459
Thank you. Post the results. Simon.
