the timer knob will not advance, no matter what time I set it on, the dryer continue to run, I have to turn off manually what could i do
Groups: APP Team
Hi. Using the multimeter check: The resistor should be about 3.77 Kohm. The timer motor contacts C-T should have 120 or 240VAc. If the voltage present - replace the timer. Timer Part number: WE4X797
