terryorie
#1 Posted : Tuesday, August 14, 2012 9:03:27 AM(UTC)
terryorie
Is this black door frame AP3118046 relatively easy to install. The frame currently on the microwave is is cracked and chipped on the bottom so it will obviously need to come off first. It's not mine so I can't see how it's attached. Thanks
#2 Posted : Tuesday, August 14, 2012 4:24:59 PM(UTC)
You can try to use the instructions attached to the reply.
File Attachment(s):
Removing the door.doc (672kb) downloaded 5 time(s).
terryorie
#3 Posted : Tuesday, August 14, 2012 5:25:39 PM(UTC)
terryorie
Thanks Gene. Seems pretty involved. This definitely helps. I appreciate your assistance.
