Crist Clapper
#1 Posted : Saturday, August 11, 2012 4:17:01 PM(UTC)
Crist Clapper
I received this dishwasher as a replacement for my recalled “caught on fire” unit. Ever since it was installed it leaks/drips from left-front door onto the floor at the end of all cycles. Then more recently the digital-display has become foggy. First told because I have a water softener… The suds in the bottom of the tub was pushing thru the bottom of the door causing the problem. Ran the unit without any detergent (clear-water) a few times… Still drips when all cycles complete. Second service replaced display (technician informed me that this was a known problem). Then with the door removed… Sealed/siliconed around the tub’s vent. Still drips when all cycles complete. I have my third appointment this Monday… Any thoughts???
Crist Clapper
#2 Posted : Sunday, August 19, 2012 5:33:21 PM(UTC)
Crist Clapper
~BUMP~
In addition to a know problem with this digital display... Which was replaced... Now there is a Vent repair/modification kit. I'm beginning to think it will never end! Help? Thoughts? Suggestions?
Crist Clapper
#3 Posted : Saturday, November 17, 2012 2:13:58 PM(UTC)
Crist Clapper
Well it’s been three months… And three replacement dishwashers later… And I still don’t have a defective-freeunit! Unbelievable… But true.
Same model unit number two: No drips, no exteriormoisture. And wait for it… Wet dishes! Open up the door and the all the walls of the tub are dripping withwater. Backing up a bit… The unit wasdelivered with the top-right corner was dented… I never saw the box, but I suspectone of the corners was crushed. Thenafter sometime… During the drain-cycle a sound started to emit. Which then escalated to symphony of whinesand moans! Multiple service calls… Noresolution.
Same model unit number three: Same a unit number two… Wet dishesagain! Although no evening serenading ofwhines and moans this time. Multipleservice calls… No resolution.
If you ask what the service technician would find… I have noidea. Lost interest.
What’s up with this no-drying thing… Anyone with similarproblems?
Last email I received from GE is chat about a buy-back.
Stay tuned!
